Help me please
350 w/203
HEI ignition? Could be power to the coil.
87silveradok20
Ohio
Levi
Silverado k20
worth checking intermittent ignition related items like ignition switch maybe having a dead spot in it, wires behind the engine shorting due to failed insulation, or aftermarket tach pulling down ignition signal randomly, and also ignition module.
I personally had issues with wires behind the intake braking insulation, aftermarket tach, and failing ignition switch, and fuel pump causing somewhat of similar issues.
Alright. I’ll have to look into that. There’s no tach so it can’t be that
87silveradok20
Ohio
Levi
Silverado k20
Well I finally found what was causing my troubles. I had a loose steering column and occasionally on right turns it would cause it to die
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Cool
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
the ol loose steering column. It'll getcha every time
Camar068
10 yrs Air Force
loose as in internally? Physical mount or wiring outside? Pinched cable? Curious for future reference.
Thanks
87silveradok20
Ohio
Levi
Silverado k20
Thanks
Yes internally. There was a lot of slop in my column where it tilts. We took it apart and checked everything over and tightened everything up and it was fixed so not sure exactly what the problem was.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I hope you loctited the 3 little bastard bolts. And stop using the wheel to get in it. Lol
87silveradok20
Ohio
Levi
Silverado k20
I did and it was loose from the po. I just do a little hop to get in [emoji23][emoji23]
Camar068
10 yrs Air Force
Thanks
cahillasher76
