Help diagnose squeak/squeal?
robm630
Grande prairie, alberta, canada
Robert
6.2L
So... my c10 with a th700-r4 has developed a low speed squeak/ intermittent squeal. It only happens below 60kph. In drive, not reverse. And I thought it might be the driveshaft, so over the last week I rebuilt the entire driveshaft, 3x new u-joints and new center/carrier bearing. And buffed it up and painted it, and it's super nice now, and that had solved a vibration I knew was from a bad ujoint. But the squeal/squeak has persisted.
When I was installing the front half of the driveshaft I turned the tranny while it was in neutral and it did squeak even just at slow speed... is this just going to be the seals on the output that the shaft slides into? Or do I have something bad happening in there..
Edit: forgot to mention. If I'm on, or ride the brakes. The squeak completely disappears... it's not any of the wheels/brakes either. When I had it on Jack's I spun everything.. it's emanating from the back of the transmission.
from
Robert Bare
MT
Robert
k20
Did you grease the output seal before installing shaft??
Robert Bare
MT
Robert
k20
Well, could be a trans problem. But, you could try some Teflon grease on the output splines, grease up the inside of the yoke.
NickTransmissions
Las Vegas
Nick
R10
I'll give this a shot later this week.
Get the truck up on all four jack stands (or a lift), put the key on, engine off thn shift the trans into neutral. Then go under the vehicle and spin the drive shaft clockwise as it would spin when in Drive - if you hear squealing sound coming from the transmission, record it the post it to Youtube - share the public link here...
If it's what i think it is, it's totally normal.
Max Headroom
