Heater Core question
tj43
Little Rock
TJ
V1500
Got the box back in during lunch today. Getting the box studs and core necks lined up with the firewall holes is easily the hardest part of the job.
I finally tilted the box back and got the lower studs started. After I did that, I went to the engine side and just barely started the nuts on the lower studs. Then I got some soft dowels to “pull” the core necks into their holes. Once they were started I went back inside and fished the final upper stud into its hole.
I probably mucked with it unsuccessfully for 45 minutes before I came up with that strategy.
Seserge
