76K20CrewCab
- Jan 23, 2024
- North Dakota
- Josh
- K20
Hello All,
New here and have a conundrum that maybe someone here has expierenced and has insight!
I have a 1976 K20 3+3. When i purchased it 2 years ago it was pretty rough but slowly I've been tinkering and making it more reliable. Now that I have it road worthy I decided to get the heat working properly. Recently I replaced the radiator and hoses as the old radiator leaked. It seemed to be running pretty cool so i replaced the thermostat with a new 195°.
Still not getting much heat ( I have front covered and truck is at operating temp). I noticed low flow from heater core return hose to the radiator when I had rad cap off so I changed the heater core.... return flow to radiator increased substanially and I am getting more heat through the vents but still not as warm as most squarebodies Ive owned. When I was running it after heater core install I ran with radiator cap off to hopefully purge the air from the system. I noticed after it was up to temp drastic surges in coolant level and as I further investigated I can feel surging in the pressure side heater hose (5/8" hose from intake to bottom of heater core) cant really feel the surging on the return (3/4" top of core to radiator).
What the helk is causing the surging? I never noticed the coolant surge before installing the new core. Am I not getting all of the air out of the coolant system?
I was worrying about a headgasket but that seems unlikely as there are no other headgasket signs....very frustrating lol
