Header Installation
Ronno6
South Mississippi
Ron
Has anybody tried installing headers onto small block prior to installing the engine into their Square Body??
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
It's not going to happen.
paulrowe
Ontario, Canada
It won't work! They'll also get all crushed and dented if you try.
legopnuematic
Licensed Junk Dealer
MO
Spencer
drivers side from the bottom, passenger from the top.
Ronno6
South Mississippi
Ron
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
You will need a quick release latch on your engine hoist. Lift engine (with headers installed) very high and release the catch. You might have to repeat a few times...
You can install and engine with the transmission attached...!
Super-Dave
Dave
We did. We were not using full length headers though. We used Hedman Ceramic Coated Block Huggers.
Dougnsalem
Umm. I thought you died last month.
(RIP Bob)
350 w/203
A video WILL be required.
78C10BigTen
pennsylvannia
C10 BIG TEN
I'll give you something different....
HEY! That sounds like a great idea! Let us know how it works out....
jk
Just drop it in fast and hard... itll go right in. A lil speed always helps
legopnuematic
MO
Spencer
Can driver's side be done without jacking engine up?
I didn't have to. It would probably help to have someone to help guide it from above to keep it from hitting everything.
Sent from my Moto Z (2) using Tapatalk
Ronno6
South Mississippi
Ron
As I have removed the inner and outer fenders,etc., it was EZ enough to prop the header up under the engine and reach down grab it, and snake it through the opening and into position.
DONE !! Now, when my proper reducers arrive, I will fit up the exhaust.
brentjo
