HD suspension option
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Ive got a 78 half ton short bed c10, standard stuff. I thought. Went through the vin with the gm manual and found that it has the HD suspention option, anyone know what that means?
Rooster336
North Carolina
Hans
When I was looking for a square the only difference I noticed with trucks with HD suspension was an extra leaf up front. Big block or plow set up?
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Neither, its 2wd with a factory small block. It all seems pretty standard
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
What's the RPO? F44?
Jrgunn5150
Ionia Mi
J.R.
6.slow
Not sure, the glove box tag was gone
There are several option, I copied this from somewhere when I was trying to figure out which trucks had four, five, or six rear leaves.
The base 4,900 lb. rated C10 used the following components at minimum:
1,550 lb. capacity front springs.
1,550 lb. capacity rear springs (consisting of 4 leaves, and having a length of 52 and a width of 2.5”).
• Front and rear tires with a load capacity of 1,470 lbs.
• Manual brake system (the 4,900 lb. rated C10 was the only pickup in the entire C/K10/20/30 lineup to use manual brakes. The front disk brakes had a diameter of 11.86” and a thickness of 1.28”. Rear brake drums measured 11”x2”).
• Standard LD4 250 1 bbl. I6 engine w/M15 Saginaw 3 speed manual transmission.
The 5,300 lb. GVWR required the following minimum additions and/or substitutions:
• Option code J50 light duty power brake system (front disk and rear drum specifications remained the same as shown above).
• Option code M20 Chevrolet CH465 4 speed manual transmission (recommended at 5,300 to 6,050 lb. GVW levels when LD4 250 1 bbl. I6 engine was selected; M15 3 speed manual transmissions remained available w/larger engines).
The 5,400 lb. GVWR required all items necessary for the 5,300 lb. rating plus the following minimum additions and/or substitutions:
• Front and rear tires with a load capacity of 1,610 lbs.
The 5,600 lb. GVWR required all items necessary for the 5,400 lb. rating plus the following minimum additions and/or substitutions:
• Option code G50 heavy duty rear springs (2,000 lb. capacity for this application. These springs consisted of 8 leaves, and were 56” long x 2.5” wide).
• Front and rear tires with a load capacity of 1,790 lbs.
The 6,000 lb. GVWR required all items necessary for the 5,600 lb. rating plus the following minimum additions and/or substitutions:
• Option code F60 heavy duty front springs (1,625 lb. capacity for this application).
• Option code J55 heavy duty power brakes (this system replaced the lighter capacity J50’s single diaphragm brake booster with a dual diaphragm unit and included larger 11.15”x2.75” rear drum brakes for C10 applications).
The 6,050 lb. GVWR package, which represents the lower of two F44 Big 10 capacities, was specifically identical, in terms of chassis and suspension components, to the 6,000 GVWR package which it superseded mid-year. Gross axle weight ratings at this GVWR were 3,100 lbs in front and 3,580 lbs. in the rear, and are the same as those cataloged for the 6,000 lb. model. The 50 lb. increase in GVWR appears to be a result of “on paper only” engineering. Emission control equipment was the only significant difference between the 1975 6,000 lb. and 6,050 lb. packages.
The 6,200 lb. GVWR was the maximum F44 option, and required all items necessary for the 6,050 lb. rating plus the following minimum additions and/or substitutions:
• Front and rear tires with a load capacity of 1,900 lbs.
• Option code LS9 350 4 bbl V8 engine w/M15 Muncie 3 speed manual transmission
Obwonkonobe
AZ
Ethan
C10 custom deluxe
@Jrgunn5150 Considering I have 8 leafs in the back I'd assume im up there somewhere, super helpful info, thanks
I had a ‘77 Ford 150. The main reason for buying the 6050 lbs and up GVW packages was that you then did not have to use unleaded gas or have catalytic converters. I think that was still the emissions rule in ‘78.
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Figures since my truck didn't have cats
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
What about 10 leaves? As far as load capacity. When they call it 1-1/4 ton, that refers to a stabile, centered load in the bed, correct? I know nowadays it’s different...
Could also be the difference of 52 inch or 56 inch rear springs too. C10/C1500 could be either or, and the K20/2500 trucks could be either or. K10/1500 got 52 inch, C20/2500 got 56 inch.
Jrgunn5150
Ionia Mi
J.R.
6.slow
Most K30's, all that I have seen, are 9 leaves. In the case of your CUCV, the payload was actually 2900lbs, could be because of the added leaf. So payload rating as it's tied to 1/2, 3/4 ton, etc, hasn't been accurate in quite awhile, but that is where it originated.
However, the 2018 Silverado 1500 is rated for upwards of 2000lbs of payload, so obviously, they've far surpassed the old naming convention.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Which was exactly the reason for the GM Heavy Half.
Keith Seymore
Motor City
Keith Seymore
4.3L
How did you discern it had the HD suspension from the VIN?
K
MattsC10
