Has Anyone Seen These Mirrors?
Craig 85
Nashville, TN
454/TH-400/NP205
I am biased, yes, but I really like the mirrors on my square... I dont know if they are stock or what they came off, though :(
They are aftermarket or around 1967-72 Ford. Kinda of a mini West Coast mirror. Popular upgrade in the 70's.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
I'm also planning to fab a brace for the inside of the door, hopefully a bit beefier than stock. I'll have some body and paint work done on my truck, so I'm not so worried about the holes from the old mirrors.
Sent from my SM-G975U1 using Tapatalk
I want to pass on a tip regarding filling the old holes. You want to cut out about a 2"x2" square and weld in a new piece. he reason is because there will be micro cracks (or not, you will see them) and they will continue to rust, eventually making a mess and further work. It's those decades of road vibrations going through the mirrors that create these micro cracks around the holes.
I live in BC where camping has always been popular, so we have a lot of Camper Specials out here and those that get restored often ditch the 4 point mirrors for the newer style. The bodyman fills the old holes with weld and moves on... only to have his work go up in rust only a few years down the road.
Maybe this is more of an issue in rust belt areas, I'm just passing on what I've seen.
Oh and welcome to the site, thanks for joining!
hunters628
Ellensburg Washington
Hunter
Called a “West coast Jr” mirror. Came standard on some ford trucks in the bump side and dent side era.
LukeDM
US
Luke
c2500
I'll sure keep an eye out for it, thanks for the info! Down here in OK, the rust isn't nearly as bad. This truck only has a little in the door wells. If I see any cracks, I'll surely replace that section!
LukeDM
US
Luke
c2500
I like them too!
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
But you might NOT see any cracks... they start as invisible micro cracks... we can't see them but RUST sure as hell does.
LukeDM
US
Luke
c2500
I see. I misunderstood your post! In my case, the body has 104k miles on it, and it has the stock dumbo mirrors. Do you expect they'll be cracked?
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
If you're investing a lot of time and $ into your paint job, I would NOT take any chances.
Understand it will cost more.. you can't expect your body man to do this without getting paid. Not a super big deal, but still, extra work is extra work.
Again, my experience seeing this problem reoccur is in a salty rust belt...
Maybe with decent lighting and magnifying glass you can inspect the hole for rust or damage and go from there.
Craig 85
Nashville, TN
454/TH-400/NP205
The D45 mirrors you have tend not to crack the door. There are re-enforcement braces that attach the mirror to the inside of the door frame.
Jimc21NC
