Guess The Tool
legopnuematic
Licensed Junk Dealer
MO
Spencer
This should be a fairly easy one:
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
The red thing is for testing antifreeze I believe. The round thing is for reeling in fish. Lol
legopnuematic
MO
Spencer
Thats one of many uses for a refractometer, just about anything from coolant to grape juice. And yep that is a fishing reel.
These were used in some way as a tool to archive results. And last one actually used as a tool
Sharpie cap used as rod bolt guides?
yevgenievich
Place
Name
Year
Model
Size
There are many uses for a sharpie cap. Never had to use as a rod bolt guide, but it should work. First time I cut one up was for fuel line disconmect tool. But later started using thin aluminium sheet instead.
Snoots
Roger
Jimmy Sierra
350 w/203
WTF!?
Keith Seymore
Motor City
Keith Seymore
R10
4.3L
Since it looks like you guys are off in a different direction, here are the answers for these:
The U shaped ones are for holding a rear axle yoke to keep it from turning while you break the pinion nut loose. (You can put a piece of black pipe on the tail to gain some additional holding force).
The second one is used for cranking the yoke off the pinion once the nut is removed.
K
Keith Seymore
Motor City
Keith Seymore
R10
4.3L
How 'bout this one:
K
Ahh, cool. Ida never figured those ones out.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
You guys tell me... i have no floggin clue, found them in the junk pile at work.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I have no idea what this one is. Was in my Dads old toolbox.
I may have an answer for you.
I showed the pic to my "experienced" technician who thinks it was for adjusting idle jets on carburetors. The shape of the spring ends kept it from slipping out of the screw slots, and being a spring it gave the operator some warning before potentially damaging aluminum seats by overtorquing a steel needle valve screw.
No guarantees, but that's what I've got.
sherrodmachine
