Greasy, oily dirty arse motor & trans
JGSR66
Mesquite Tx
Jerrie
i have not owned my 85 c20 very long and it has grease and gunk all over any suggestions on what to use to clean or just regular engine degreaser?
74 Shortbed
Good ole Gunk works pretty good..
Crispy
Carbon County, Pennsyltucky
Suburban V1500
I've had luck with Gunk degreaser. You may have to scrub some spots with a steel brush. I always wrap plastic baggies around electrical connections then tape the ends to minimize water exposure. I also dont drive the car for at least 24 hours after. I've done this on fuel injected cars with success. I would imagine you have less electrical connections but you have that big ol carb hole to cover.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
it may sound fruity, but I'd do it at a pay and spray wash. their drains at least have some sort of filtration before it goes anywhere. i don't want our bass and salmon gunk flavored just yet. I'm always leery of doing that sort of stuff at home for my downstream neighbors sake. they and their animals drink the water from the aquifer below my property and the water table is high here. when you do it, I think the can even says use minimal water necessary for the job. okay you can make fun of me now.
edit: the last engine I did this to was so dirty you couldn't really work on it. I put a sheet of poly down and scraped as much of the crud off that I could before having at it with the can of chemicals. an old worn out flathead screwdriver with rounded edges works great.
rpcraft
Robert
LS 6.0 364 CID
nothing helps more than physically scraping any accumulated stuff off. after that I usually attack it with Castrol Super clean and let it sit and work for a little bit then spray it off at the car wash as others have mentioned. That is kind of a step 1 2 and 3. After that I go home and soak it down with the super clean again and let it sit for a bit and hit it with my power sprayer, but i usually find a grassy patch where I don't mind the grass looking a little worse for wear for a little while. Mine's not a beast but its got more oomph than the car wash does and does a much better job of blasting off caked on stuff. I'm at a point where I need to take my motor out and revisit the cleaning process on my transmission and transfer case so I can get them clean enough to prep for paint. Probably just going to go with a dark cast color or something simple.
JGSR66
Mesquite Tx
Jerrie
Cool I’m gonna go get some gunk I’ve already been scraping off stuff & don’t worry got southern engendered catch-all tub to protect all our lil fish friends.
#BASSLIVESMATTER
LMAO
Craig 85
Nashville, TN
454/TH-400/NP205
I swear by this stuff. You can find it at the Dollar Store.
Lil'm
Lake Bluff il
Vince
K10 shorts
CRC Brake cleaner and carb cleaner work quite well and are usually way cheaper than gunk. Menard's puts both on sale quite often for 2 bucks a can and I buy a lot of it then. It evaporates pretty quickly so best to saturate a section at a time. Cover sensitive electrical and pressure wash in short bursts.
SDJunkMan
Black Hills of South Dakota
Jeff
Gotta love Menards. They have CRC brake clean and Sta-Bil carb cleaner on sale for $2.49 this week, plus an 11% rebate.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I worry about hard chemicals like Brakclean and Carb Cleaner damaging composites, but my worries aren’t founded in any proof. I like Krud Kutter and a pressure washer, which you can find in the paint/hardware section at Walmart, Home Depot, etc. They also have a line of automotive products. I believe it’s water based and biodegradable to answer the concerns of @Frankenchevy.
BrianBaca
