Govoner
oltrsty
Bulverde Texas
Teddy
c-2500
Hi guys I am new to this forum. I have a 1984 gmc 3/4 ton with a turbo 400 transmission. It was stuck in first gear. I found out that the governor plastic gear had been worn smooth. I put a rebuilt governor in it, but it only lasted about a month before its gear was worn out. Has anyone had this problem before?
NickTransmissions
Las Vegas
Nick
R10
This issue is likely caused by a severely worn rear transmission case bushing. When the bushing is worn, it allows the output shsft to oscillate in ways that cause the drive and driven gear on the governor to fall out of mesh.
Is this a two-wheel drive truck?
ali_c20
Austria
Alexander
C20, K5
Welcome from Austria. You found the right place, this forum is a wealth of squarebody knowledge. Post some pics.
oltrsty
Bulverde Texas
Teddy
c-2500
Yes this is a two wheel drive, with heavy duty towing package.
