- May 13, 2019
- Oregon
- Eric
- K25
- 350-4bbl
You said earlier that you had properly set the idle. You also said that you set the timing earlier? How did you do any of that if you don't know the idle set procedure for TBI and don't have a timing light. You CANNOT set timing properly without a timing light. You can get somewhat close, but it will not be right. Go buy or rent a timing light from a local parts store. Bonus points if it has a tach function. Double bonus points if it can be dialed back.Disconnect battery ,Unplug my est then I thought I had to turn the crankshaft by hand to get the rotor pointing roughly in the 7 o’clock position or 1/3 between the #1 firing order and #8 firing order on the compression stroke . Put back on distributor cap and wires then Plug in est , reconnect battery. Start the truck Then adjust distributor cap by feel or intuition. What part of my method is wrong? Thank you everyone!
The "turn all the way in and then back out 1 turn" is for setting initial idle mixture screws on a carburetor. It has absolutely nothing to do with IAC and mechanical idle setting on a TBI unit. I am getting more and more concerned with the total confusion happening on this thread.
You need to do a full stop and reset on what your thought process is on this truck right now.
First things first, get a timing light.
Find the correct connector for setting timing. Take a picture, point it out or circle it, and post here so that someone can verify that it is indeed the correct connector for you to be unplugging.
Once you have the right tools and know EXACTLY what you are supposed to be doing... then you can fully warm up the truck and set the timing to 0 BTDC using the proper tools and procedure. If you have been setting timing to 12 degrees BTDC by manually turning over the motor to that setting and then putting the rotor on #1 post, you could be WAAAAAYYYY off on the timing.
Once you have set the timing correctly.. it will most likely run MUCH better. Now you can go through the procedure to set the idle and IAC.
Set procedure for idle and IAC involves jumping the A and B wires on the ALDL connector, turning the ignition to ON(not start) for 10 seconds, then turn key off and unplug the IAC valve and remove the jumper wire. Then you can start the engine and adjust idle to 650RPM. If you don't have a tach, timing light with tach function, or ALDL reader, this step will be hard to impossible(you'd be amazed at how hard it is to do this by ear).
The idle set is completely invalid if you have ANY vacuum leaks and/or your timing is not set correctly. DO NOT do it if you haven't solved all of your other issues first.
