Got 8 inch springs.
mavtricks71
az
mike
So I went ahead and ordered front 8 inch springs. These things should be a direct bolt right? No changing shackles ect? I'm buying all parts a little at a time.
Are you stock hight right now? If so, you will be 2wd and will be without steering if you didn't get anything else to go with the springs.
mavtricks71
az
mike
I'm gona buy everything a little at time raised steering arm ect.....but my main concern is do I need a different front shackles or will originals work ok?
In theory you would need much longer shackles, because the spring with more arch has more room to compress and swing the shackle into the frame. But in reality, they will be stiff and not compress much at all. Worst case, a little longer shackle could be useful, but those aren't hard to change later on.
mavtricks71
az
mike
I'll watch out for that when I install them....thanks
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Adding longer shackles will give an ugly front pinion angle. Yes there are wedge blocks to correct this. So does adding to the front spring mount to lengthen evenly.
jlyon1006
