GMT-400 Alignment issues
oneluckypops
Sedalia, Mo.
Luke
K30 SRW
Took my daughters truck in for an alignment today. They checked the front end out and said all was good so I left, hour or so later they call and say they cant align it because the Caster and Camber are to far out and wont pull in. The knockouts have supposedly already been taken out, and the torsion bars are NOT cranked up! How ever it does appear that it has either had new keys installed or aftermarket torsion bars because the Front end does sit higher then normal. The guy doing the Alignment would not do anything to fix it, evidently they don't do any repairs only alignments so I know he wasn't just trying to "sell" me something. He did however turn me on to an Aftermarket Bushing that is drilled offset of center and allows for more adjustment. But again he wont install. I have been looking online and so far all I am coming up with is a 1 degree offset bushing, and I cant remember what the print out said as far as how far out it is to know for sure if the 1 degree will resolve the Issue. Ive seen 2 degree also but unclear on fitment of vehicle as well is if its +/-2 degrees each way or if its a total of 2 degrees (+1-1= 2 degree). Any advise would be much appreciated. Not opposed to just swapping the entire control arms out either.
She does not want me to lower it back to stock height either so that rules that out.
Oh the truck is a 1997 K1500
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Seems possible you could have a bent control arm if the camber adjustment is maxed out and the wheel is still leaning... OR wheel bearings?
You said k1500 so its 4x4, they use a unit bearing... It's not like older 4x4 solid axle with a spindle and hub
On those trucks the hub and bearing are one... If the bearings are shot it'll cause it to lean some.
Just some thoughts.
I've dealt with ifs ALOT unfortunately... Which is why I did a solid axle swap lol
(not suggesting you do that)
oneluckypops
Sedalia, Mo.
Luke
K30 SRW
Just some thoughts.
Doubtful the arms are bent because both sides are the same. I am all to aware of the wheel bearings but everything in the front end is new. Seriously want to do a SAS on it but I cant find a furd front differential here for anything. Maybe I just have better friends then people with furds :dogpile:
Vbb199
Salisbury NC
Vince
Picked up my kingpin 60 (87-91.5, 36.5 Centerpin distance) for like... 900?
Got a spare axle in the deal for another 600
oneluckypops
Sedalia, Mo.
Luke
K30 SRW
Hell I would be happy with just a 44, she never going to do any seriouse wheeling
Vbb199
Salisbury NC
Vince
I mean... Those aren't too too hard to find. Lol
The guy I bought my axles from sells, refurbishes, mods, and whatever else 1 ton axles.
I just got ****** old takeouts from 87-91.5 ford's, and a 99-06 14 bolt disc brake rear for the s10 in my picture.
Vbb199
Salisbury NC
Vince
If both sides are out the same amount, I'd be inclined to think those replacement torsion keys might be the offender.
I misread, thought you said just 1 side was out.
oneluckypops
Sedalia, Mo.
Luke
K30 SRW
Yea just trying to figure out how to fix it with out removing she doesn't want to looser her ride height
Vbb199
Salisbury NC
Vince
I think I'm just screwing up everything here and blabbing Lol I've had a long 14 hour day
idahovette
Weiser Idaho
Perry
K20-K10
Did they give you any kind of numbers for the caster and camber, maybe a print out to prove how far off? Why the alignment, any wear on the tires, driving bad, pulls, what was wrong to start with?
Vbb199
Salisbury NC
Vince
I will add, I think the camber shims are +1 and +2.
Not +/-2 and so forth.
That is my major contribution to your search for answers, and it's very little aid.
oneluckypops
Sedalia, Mo.
Luke
K30 SRW
Yeah they gave me a printout but I left it in my truck and haven't been back to get mine yet. Took it in for an alignment because the Camber was noticeably out just bye the eye and and it is pulling to the right. Havent driven the truck enough to know about uneven tire wear.
Jethro224
Illinois
Those trucks just don't take well to raising ride height unless you do it with a real lift kit or sas. The offset bushings are kind of a hack. They can sometimes correct the angles but have their own issues.
oneluckypops
Sedalia, Mo.
Luke
K30 SRW
Well Im all ears to the issues they have on there own
Jethro224
Illinois
All the ones I've seen must be installed in pairs at just the right rotation. The hole is offset from center so one side has way more rubber than the other making the bushing weaker on one side. They don't tend to last as long.
Then, even if you do get the alignment right where you want it, the geometry of everything else is screwed up still. Travel is limited. Axle shaft angles are steep. On and on.
Best to just lift em right or don't lift em.
The stock setup gives quite a bit of adjustment already if your alignment guy does it right.
It's your truck tho. Do as you see fit.
Nuggets40
