glue in panel?
JohnRod
Kingman,AZ
Rod
2500 Suburban
I have a stepper or flange air tool. what do you do about or with corners in the body when you are stepping?
a good explain would be appreciated.
thanks Rod in AZ.
Terry Wilkerson
Kansas
Terry
GMC 1500
If I understand you right round them off.
JohnRod
Kingman,AZ
Rod
2500 Suburban
what I should have said, is...do you cut a pie shaped piece out of each corner, so you get a square corner. and do that before stepping.
thanks Rod in AZ
jimlayhee
