SDJunkMan
- Nov 17, 2017
- Black Hills of South Dakota
- Jeff
- K10
Thursday I was getting ready to put the plow on the CUCV in anticipation of the snow that was coming. Started it up, moved it to where the plow is, and let it idle for a minute while I moved my other truck, and it died, like someone shut the key off. It was in the teens, thought it had winter blend in the tank, but it wouldn't restart, not even a cough. Put some diesel 911 in the tank, and checked tne filter, which was.not gelled. Thought possibly the voltage was low, and caused the solenoid to shut off, so put the charger on overnight and plugged in the block heater. I tried to start it this morning and it doesn't even try to fire. It was down near zero the last two nights and tne highs only in the teens the last couple of days. I opened the drain on the fuel filter to see if it was pushing fuel out, and it wasn't. Hoping its just gelled, and will thaw when it warms up today (supposed to get in the high 30's today).
Is there a easy way to tell if the pu.p we t out, or should I just give it time to thaw? I really need to plow my lot. Unfortunately I don't have a warm place to park it to help thaw it out.
