gas tank pushing fuel out the cap...
cbsuguy1
iowa
george
scottsdale k 30
dual tanks on 82 , right tank works fine... switch to left and ran for short time fine then started spewing fuel out cap and running like crap. first time i have had any problems with fuel system and i have put several tanks of gas through both sides. any ideas?
bedwards
Adger, Al.
Bryan
c10 Silverado
Mine did it and the tank selector valve was bad. Pumped enough fuel from one tank into the other to overflow it and up through the vent into the carbon canister and ruined it and flooded the carb.
SirRobyn0
That sounds about right to me. You'll need a tank selector valve and you'll need to replace the carbon canister as I'm sure it got flooded with fuel if it made it run bad. If you don't already know the tank selector valve is somewhere under the cab and the canister should be in the left (driver side) inner fender well by the radiator.
ExtraZ
