Gas Gauge Off The Deep End
Ronno6
South Mississippi
Ron
1984 C10 dual tanks.
New tanks, at least 1 new pickup/sender.
Just installed gauge cluster after 2+ years.
Gas gauge travels WAY past full...........same for both tanks.
Maybe 5 gal in each tank.
Tank selector switch and valve working.
Sound like a ground issue??
Both tanks at the same time??
Gotta fix before I re-install the steps...
Camar068
10 yrs Air Force
when you've got the cluster out, run a wire directly to it and see what it reads. I used speaker wire and gator clips I had laying around to troubleshoot it.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
They'll peg out in my orange truck if the sender wire isn't tight and making good connection at the sender.
Iirc, poor connection (ground or signal) will cause the gauge to peg on empty. If the sender wire is grounded, it will peg on full. Unless I have that backwards...
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Mine is pegging full. But I have either a bad switch or switch valve, so that may be my cause. Dual tanks.
But mine is for sure doing it when the sender wire doesn't have proper connection, on both tanks too, otherwise when properly contacting the gauges work fine, so I think my switch is good.
I thought fuel gauges pegged way over full with an "open" circuit. Not plugged in or grounded. Like the oil pressure gauge? I think? Maybe oil pressure pegs if grounded, I can't remember right now lol
I'm betting I was remembering it backwards.
ali_c20
Austria
Alexander
C20, K5
Good videos for gas gauge troubleshooting:
Jgonick
West Texas
Joel
If anything lowers the flow of current the needle moves towards Full. (or 3 O'clock with no current)
so possibly a bad connection with sensing wire (pink) or bad ground. If both tanks are doing it- I would start by checking the pink wire connection at the fuel selector valve & firewall (bulkhead) & back of gauge (make sure nuts are tight)
Another great video
michaelk20
