Fuse panel add on wires?
ChuckN
Bellinham, WA
Chad
Just curious- the LMC tach kit I purchased says to hook up to “switched 12v power”. A friend of mine a while back mentioned add-on fuse wires that plug into the fuse slot and adds a pigtail that then can be used for something else. Has anyone ever used one and are they a bad idea? I just thought of these instead of chasing down a wire that I could accidentally mistake for something that isn’t switched. Thanks in advance!
AKguy
Alaska
Randy
K30 Crew Cab Silverado
Looks a lot cleaner than some of the stuff I have encountered and as long as you don’t exceed the load I imagine it will work fine. If the butt connectors are not heat shrink with sealer I would replace them with such.
ChuckN
Bellinham, WA
Chad
Thanks! I’ll likely pick a circuit that is low amperage, a tach uses very little juice.
install them the correct direction (can be googled) because they only go one way
Ihave used one for my carb choke.
In your case for gauges? oh youre good
I would, in my case, use the gauges fuse if i had to in your spot. You may have a larger box than mine, but iirc the fuse box taps that are 1 wire that come off are usually like for what you are doing, so if unused and you found an easy way to get on the terminal one could probably use that, but I dont recall how those work
just make sure its for a regular full size fuse (ATC?) not the mini ones picturd. I have loads of the small ones and a few large ones, the mini ones I used one in my car to power an additional power in the rear of the car for something
1980 Big Ten
Virginia
Darren
C10 Big 10
I just used one of those add-on pigtails to run constant power to a new stereo head unit in the headliner (for the memory). I tapped into the horn/cab light fuse. This video helped:
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Probably a good idea. I have a monster tach that was intermittently working. Now I hardly ever notice it on. I know something happened and maybe the fuse is a good filter.
sidschev
Arkansas
sidney
c1500
ive used the minis on my Tacoma/Taco for the add on driving/fog lights ....worked real swell.......
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
They work just fine.
99tan99
