Fuel sending unit
RamblinGMC
Clovis Ca
Eddie
c2500
Switching to gas from diesel. Curious if the sending units in my tanks will be ok with gas. Thanks!
RamblinGMC
Clovis Ca
Eddie
c2500
I just need to know if the sending units are the same between gas and diesel. I'm seeing different part numbers between the 6.2 diesel, 454 and 350. But the tanks are all the same. 20 gallon dual side tanks.
RustyPile
Left on own accord
Elkhart, TX
Nick
1983 GMC
350 SBC
If the part numbers are different, the sending units are different... They're also different side to side..
Buck69
Northern British Columbia
D30 CUCV
6.2 (removed)
The only difference is likely to do with the ports. Size or possibly number. The sender itself has the same resistance range.
I just swapped over to gas from a diesel that had been in storage since 2005. I also switched the gauges as well since I had both and didn't want "Diesel Fuel Only" on the current gauge.
Anyway, the sender is reading out some and needs to be replaced. It shows 1/8 while empty and 5/8 with 9 gals in it. Both the old diesel and replacement gas gauge read the same.
mxer147
Colorado
Jack
k20
Ethan_H
Lebanon, PA
Ethan
C20 Silverado
6.2L Diesel
I've got gas sending units in my diesel, so vice versa should not be a problem. Difference in part numbers is due to 1, 2, or 3 ports. Only difference between a 3-port gas or diesel unit is the plug for the "water in fuel" light on the diesel.
seanhatesregister
