Fuel pump pushrod stuck??...
79trumpduck
Clayton, GA
Kenzie
C6000
So I recently purchased a 1979 gmc c6000, the thing ran fine until I stopped by my house on the way to a job to fix my drivers side door. I turned it off for a minute came back and it wouldn't crank. Checked the gas and the tank was full of rust. Had a friend diagnose the problem as the fuel pump. Took the tank off cleaned it out, replaced the fuel line, filter, and my friend replaced the pump. Still wouldn't crank. Checked the pump only to realise it was barely on there... took it off and now the pushrod won't slide out... tried everything... about to burn the thing to the ground and take what's left to the scrap yard....
79trumpduck
Clayton, GA
Kenzie
C6000
No... but I guess he just shoved the pump over it... finally got the pushrod out and it was bent pretty bad
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
DAMN !!!!!!
Do you realize how difficult it is to bend one of those hardened steel rods ??
I would not allow your friend to work on any of MY trucks .........
350 w/203
Pix pleez!
Itali83
Maine
Ben
K10, 'burban C10, Jimmy
That is one of the most impressive things I’ve heard in a long time. I’m not sure I could bend one of those trying. But this guy was like Mr Magoo and had no clue he was doing something so stupid lol.
Ben
Backfoot100
Florida
Eddie
C1500 Suburban
Carbed 350
Wow....for the life of me, I just can't imagine how that's even possible.
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
I'm not sure I would trust the guy who did that to even be a pastry chef ....... can't help but wonder how bad he could screw THAT up .......
fast68chevy
I am the original fast68chevy
LINCOLN IL
RANDY
wow damn this is a first for me to see one of these rods bent wow...........! :O a pen mzgnet and a small hacksaw blade are all you need to rmeove install these rods. and also some thick grease, but puting in a longer bolt into the threaded bolt hole also will hold keep the rod up in place when its up on the backside/heel of the lob that it rides on.
Swearbody
Birmingham AL
Jeff
C1500
355 sbc
i wonder if the bend lines up with the hole in the block. only way I can see it getting that much lateral force is having a bolt ran into it sideways and even that doesnt seem possible
Galane
Idaho
Gregg
Sierra 3500
I'd be wondering about the condition of the pump lobe on the camshaft.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Better check your cam lobe, may have punished it in the process. Use wheel bearing grease on the rod, helps keep it up, and also, install with the cam lobe in the up/away position, not towards down. Just did this a month ago. Good success.
ExtraZ
