SirRobyn0
- Dec 6, 2019
- In the woods in Western Washington
- C20
Ok I'm not sure how helpful I can be but I'm going to throw my 2 cents in, part of this is so the thread will show up in my feed you up load the pictures.
My knee jerk first reaction is that your pinching a hose when you put the tank up. I have dual tanks, and I have to left side sending units, because at the time the right side was back ordered, so the only difference is orientation of the ports, and looping longer hoses around is the solution. My point to all that is there is some room up there, but still it can happen. But if those hoses are 40 years old and they are routed a little different the pump when trying to suck gas up might be sucking a fuel line closed. This would be exacerbated by the 40 year old pick up screen on the end of your pick up tube, if it's causing a restriction that puts more suction in the fuel line. It's also possible, because you can't see the inside of a rubber hose, it's possible for them to break down inside, then you wiggle it around those rubber chunks break loose and either plug up the line the switching valve, or at the fuel filter.
If this truck was towed into my shop right now the first thing we'd do is drop the tank and replace the rubber fuel lines and the sending unit, or at least the pick up sock.
