Fuel leaks down?
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
What's a 3/4 cam? :insane:
But really I have the same issue. Long cranking to get fuel after basically anything more than a day of sitting.
I've tried check valves, fuel pump, and replaced the pump to carb line section that had a bunch of connections (8 or more maybe don't remember). All with no change to the amount of cranking before firing off.
The previous owner's open air cleaner can't be helping either.
SquareRoot
I've always wanted a Mopar 440 with the three third carb setup.
80BrownK10
Greenwood, SC
Nate
If you can't live with it swap in a electric pump with a regulator. Just wait a few seconds then start. You will have fuel instantly.
Ewhitaker0020
I watch an old school Mopar guy on YouTube. His channel is called uncle Tony's garage. He talks about this. He said current gasoline especially with ethanol in it evaporates like that and it is just a characteristic of the new type of fuel. I have the same problem with my truck. I commented on one of his videos and he said yes that's just the way current fuel does. All his cars he said do that.
I don't know... I can let my 84 k10 sit for a week or 2 and it will start withing 3 seconds of cranking. Edelbrock carb, but original fuel pump.
Ewhitaker0020
You sound like an exception
I'm really hoping I don't get that problem. Why would you have to crank for 20+ seconds? Wouldn't the fuel pump be able to get the fuel there withing a couple seconds regardless? It's not a long distance from the carb to the tank. Could it be a problem with the fuel pump barely pumping?
80BrownK10
Greenwood, SC
Nate
I put the fuel pump on maybe 14 years ago. I haven't driven 8000 miles one it. But it's done this with the pump before and this one since I replaced it. I replaced the old fuel pump cause it was leaking externally. They are cheap and I had no idea how old it was so I just bought a new one and installed it. This truck will sit unused for weeks and in some cases months.
If I drove the truck the day before it will crank cold start even if it's 35f outside or 95f outside within three seconds just like was said by the last guy. But after three days to a few weeks I have to crank for 10-15 seconds. I don't know why that's the way it has been for me and it also sounds like plenty of others have this trouble . Now if I daily drove this truck I wouldn't even know if it had this issue cause from day to day or a few days in between trips it doesn't have this issue.
Only thing in the original designed system that I have is a clear plastic filter that I replaced about a year ago inline on the frame in the engine compartment. And my original hard line to the carb had been twisted and bent from someone not holding it tight with two wrenches. So I fabbed up a metal stub about 6"s long out of the carb to connect to a rubber line back to my clear filter.
It's been maybe 6-8 years since I replaced the internal carb filter, but it is behind the primary clear inline plastic filter I mentioned earlier and also the fact that I haven't put 16,000 miles on this truck in the 15 years that I have had it, and the fact I have replaced the filter a time or two I don't think it is restricting flow, especially since when I stomp it it doesn't stumble and gets all the fuel it needs.
73c20jim
Tombstone, AZ
You sound like an exception.
So am I. One pump to set the choke and it starts.
MrMarty51
Eastern Montana
Martin
If anyone does install an electric fuel pump, may I suggest to be sure to remove the mechanical unit and block off the hole.
Reason being, the mechanical pump can rupture a diaphragm and leak fuel to the cranking case undetected, I guess We all know the results caused from fueled down oil.
goodwrenchca
