Fuel gauge
frank82
Godfrey il
Frank
Hello everyone. I've got an 82 c10 with fuel gauge issue. Been running on the left tank since I got the truck. Gauge always worked fine. All of the sudden it stays between 1/4 and 1/2. Cleaned ground no change. Decided to try the right tank. KOEO can hear valve switch . Runs fine but gauge is past full even after siphoning 6 gallons out. Cleaned that ground also. No change. Don't know where to go from here
Dmack
Central OR
Dave
Past full means open circuit (ie broken/disconnected wire.
Seserge
