dhenderz
- Nov 30, 2018
- Michigan
- Dennis
- K10
Has anyone found an easy way to replace the bushings on the front sway bar on these trucks? I am not talking about the center (fwd) 2 bushings that the bar pivots on. Those are easy. I am talking about the 2 that are press fit into the ends where the bar is bolted into the leaf spring brackets (at the axle).
Here are the ones I am talking about -
I had to burn & drill the old ones out of the bar. These new ones (AC Delco brand) appear to be at least 1/8inch in diameter larger than the hole in the end of the bar.
