Front Rear Shackle Frame Bushing
firebane
Calgary, AB
Curtis
Yes it is its part# 7801 on that page and the part# for Summit that I have in my hand is 3.2111G (GM 4 X FRT SPRG BUSH)
FORGET THAT!!!! ITS THE WRONG BUSHING one sec......
LOL. Exactly. HDR says its the same as the leaf bushing but I need to be sure. Which is why I was just going to crawl under the truck and do some investigating.
highdesertrange
kalifornia
mike
k30
it's the same as a factory spring bushing. several people sell it. highdesertranger
MadOgre
NA
NA
NA
NA
NA
Only it uses a smaller pin so its not the same unless you use custom shackles
highdesertrange
kalifornia
mike
k30
ok let me try this again. on a factory truck the front springs rear shackle, both the bushings are the same. the spring bushing and the upper shackle bushing are the same. so is the hardware both bolts are 7/16" dia. now if yours isn't somebody has changed something down the line. highdesertranger
MadOgre
NA
NA
NA
NA
NA
LMAO Before I went all sideways on you I thought I best go double check and of course I was wrong lol
Yes it seems that both bushings use the same OD and ID and the same bolt size. However the forward bushing on the front leaf spring is bigger in both ways.
I think I was confusing the back leaf spring for the front one LOL oh well :sorry:
firebane
Calgary, AB
Curtis
all good :cheers:
jmbcary44
NC
Jon
v1500 Suburban
5.7L 350 SBC
4 link...?
firebane
Calgary, AB
Curtis
Grade 8 bolts and 3/8 steel being bought this weekend. Will post updates.
Clutch
Dirty Jersey
K30 Silverado crew cab dually
L82 350
Here's a question. How do you get them out without a great deal of agony? I need to do mine and I'm dreading it.
highdesertrange
kalifornia
mike
k30
the easiest way to get them out is to burn them out. take a torch and light them on fire, once lit they will burn on their own. it's a stinky smoky mess but they will burn right out. then take a punch to the steel sleeve and drive it out, taking care to not mar the bushing retainer. highdesertranger
ajd89
Central Michigan
andrew
If you dont have a torch you can drill the rubber out lots of 1/4" holes and then it will lossen up and you can knock then out also
Clutch
Dirty Jersey
L82 350
That's kinda what I figured. Well I figured oxygen acetylene and air chisel thanks guys
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
That’s how I do them. Just have a bunch of junk 1/4” bits on hand.
jimlayhee
