Front end noise
The u-joints on the drive shafts seem fine (no play at all) but idk how old they are. I replaced the axle u-joints this spring which is when I replaced the bearings as well.
Also my hubs don't lock
You have NP203 with always locked hubs?
Auburn, Washington
If not bearings or u joints in the front and nothing loose with the brakes, and presumably speed variable noise, I’d start looking at the front diff or transfer case. Remove front driveshaft and see if noise disappears or can isolate it further? Being full time 4wd everything is spinning all the time.
Fjordlander
USA
Kyle
Scottsdale K10
V8
Can you temporarily remove the ends of your hubs so you free wheel to see if the NP203 differential is doing its job
I put the truck on jack stands to see if the front diff was working and it is but the rear wheels started spinning instantly whereas the front was delayed and much slower. Is that normal or is something up with my diff?
Fjordlander
USA
Kyle
Scottsdale K10
V8
Push up and down on the front pinion yoke,looking for a sloppy pinion bearing.
The driver front yoke does have a little play in it! Is that bearing replaceable or do I just need a new yoke?
mtbadbob
Montana
Bob
V20
Front shaft CV wore causing it to bind with the lift??
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
you got the chrome tin covers on your hubs? Haven't seen those in a coons age lol. There reliable but definitely keeps parts moving when you don't need them too. Any plans for manual or auto locking hubs? And how much pinion play are we talking about here? Little wiggle or flop donkey status?
Wrund1
