Front End Alignment???
jjewett444
New York
jim
anyone had their square aligned or done one themselves on a alignment rack? I was at work(garage) and want to have my 84 c10 lined up soon so I checked for specs and they are there except there are like 10 different ones for a 1984 c10 shortbed with only a code haying like h4 or h5 or something like that and I have no idea where to decipher what this means lol so if anyone has some experience with this it would help a lot, thanks BTW alignment setup id hofmann if it helps
chengny
The 1984 service manual only shows one set of specs for all C10's:
jjewett444
New York
jim
what manual is that? Haynes or chiltons? I will check some of the options for the c10 short wheelbase to see if all toe caster, camber, sai, and thrust angle are the same. if so I guess it wont matter then. btw thanks for the pics of specs, wish I had seen the a while ago lol
jjewett444
New York
jim
I'm trying to make sense of caster chart because there are 11 different measurements from 2 1/2" to 5" called "dimension A". what is this dimension referring to? looks like it is pointing to the coil spring lol
chengny
Those specs are from the 1984 GMC factory Service Manual. Maybe the attached dwgs & text will help make what they are saying clearer.
First the text:
A better dwg of how to determine dimension "A":
An exploded view:
Where to add/remove shims to adjust caster & camber:
jjewett444
New York
jim
hey thanks a lot man. I now understand the caster measurement and what the numbers are. when I looked at the specs at work it did not specify what to measure so I was clueless lol. now is the decision of changing all control arm bushings to polyurethane as well as all leaf shackle bushings and tie rods or not lol. my luck the originals will go as soon as its aligned
RustyPile
Left on own accord
Elkhart, TX
Nick
1983 GMC
350 SBC
"Dimension A" is a reference to ride height.. The lower your truck sits, the shorter this dimension. The higher it sits, the longer the dimension. In some cases with lowered trucks, camber is a compromise as there isn't enough adjustment range to obtain the specified setting... Camber varies as the suspension moves through it's travel range.. There is an order to adjusting the settings as any change in caster or camber affects the other two. Set caster first, then camber, and lastly toe in/out...
zapattack
