Front driveline too short after lift kit.
Isaac nickerson
Hillsboro Oregon
Isaac
5.7 L
Hey guys, got the 4 inch RC lift on the truck finally, but the front drive line is about an inch too short fully extended. Does anyone know of an aftermarket driveshaft or spacer for a 1977 k10? I would prefer not to have to go to a shop.
Curt
Loco Hills
Curt
K-30
JE REEL has done 4 driveshafts for me.So them featured in Peterson’s 4wheel & offroad years ago.They make heavy duty shafts.Your gonna pay for it…might I suggest that if you do get a new shaft you upgrade your front pinion yoke to a 1350 series.
Or just find a local shop to re-tube it.Might as well have them rebuild your CV portion.Probably cost about 250$
dhenderz
Michigan
Dennis
Isaac nickerson
Hillsboro Oregon
Isaac
5.7 L
How much extra length of play is a good amount for the slip yoke?
Rumbledawg
the back 40
K30 crewcab
i have 8"s of lift in my K30 with a mostly stock shaft.
transfer case is dropped an inch, ground out the stops on my cv and bought a longer slip yoke. i did rip the ball outta the cv and replaced it with a H-D one couple yrs ago.
i think i paid around $125 for a longer yoke
Curt
Loco Hills
Curt
K-30
For a stock truck,that doesn’t see heavy suspension movements,an inch either way is good.So you have an inch to extend and collapse.In other words 3 to 4 inch’s total movement and ideally, sitting in the middle of that at ride height.
The front on squarebody 4x4s extend,while the rear collapses.Assuming stock suspension or leaf springs.
Isaac nickerson
Hillsboro Oregon
Isaac
5.7 L
So I ended up just taking the over extension clip out of the driveshaft and ordering the 1 inch spacer. Should have about an inch of play before it shows the splines. So I'm calling that good. However I dont know if should rebuild the cv. It is really stiff and requires some force to move. I'm wondering how easy/expensive it is?
Isaac nickerson
Hillsboro Oregon
Isaac
5.7 L
Also I forgot to mention the reason I got the spacer is because portland driveline quoted me 700 bucks to do the whole job
seanhatesregister
