Front Drive Shaft Bolts
Jerry,
That is some serious HOWTO/Pin worthy info. Thanks! :headbang:
It does look a bit involved. But I don't think I need to do it.
Driveshaft barely clears the crossmember, probably 1/4 to 1/2". And when I romp on the throttle it clicks or when the chassis is torqued. My first guess would be worn T/C bushing/mount on the crossmember? Maybe my motor mounts?
I'm not sure I'll fix it, its not terribly violent and I don't really use 4WD all that often.
I'd go under and check but its too snowy and cold to bother crawling around under that thing right now.
Sounds like it. Motor and/or Tcase mounts have gone soft.
Larry S
