Doppleganger
- May 24, 2019
- OH-MI: Just like it sounds
- Chris
- K20
I'm sure this is old stuff for you fellas but I never did it (yet) so have a couple quick and easy questions.
Putting my front axle back together. The top ball joint has that threaded insert. I know I need to tighten the top nut to preload the lower ball joint so I can tighten it (the lower) without it turning. Not even 100% sure what that threaded insert does.
So how far do I tighten the threaded insert, and in what order (threaded insert, lower ball joint, castle nut), and how tight? Yes, I have the spanner socket to do the insert.
This is where they are sitting now:
Thanks in advance.
Thanks in advance.
