Frame Swap
mike gerhart
pa
mike
I have a 78 chevy 1500 4wd short bed with a rough frame. I found a 1986 nice frame front looks different at the end of rails. Bumper mounts may need changed but wanted to make sure everything else will bolt up. Thanks
Shorty81
Baby Boomer
North West ohio
Darren
I have a 79 frame and 86 cab and bed. The frame horns are different, I used a 79 bumper.
Sounds like the horn being only difference(what is a frame horn?) everything else worked well for you, shorty?
Frame horns is the very front of the frame. The 73-80 frame horns are rounded off and look finished. The 81-91 frame horns are a sharp point where it looks like the frame is cut off at an angle.
Is there a reason they did that change?And does it affect much else?
Shorty81
Baby Boomer
North West ohio
Darren
Yes, everything worked out fine. Luckily I had access to a 79 bumper. I wanted a painted bumper but had to settle for chrome. I think the frame design change was a cost cutting measure.
eskimomann209
Modesto
Marcus
Can mounts aren’t interchangeable. you need the one’s for the correct frame. so you’ll need to factor that in
frank76
