FM Radio Antenna Extension Cable?
91burb2500
Plantation, FL
Joey
Suburban R2500
Trying to get my FM tuner working properly on my 91. The antenna base was busted, but I was able to extract the stud and install a new one with a new GM antenna. Problem is the other end is not connected and the original cable that ran through the firewall is cut off at the grommet. What type of connector did GM use? It’s a female coaxial but is smaller than the usual one on the back of most radios. What is it called so I can try and get a new extension cable to make the connection?
Seserge
