Flat beds anyone?
79K15 HIghSierra
South Carolina
Reuben
K1500
Anybody put flatbed/ute beds on their squares? My bed is a bit rusted out and thinking about it. Wood, metal, a combo of both? Throw up some pics!
75Monza
Colville, Washington
K30, K20, K20
I've got one I am putting together for my 80 K30. Its metal fame with wood bed, but since wood rotted, going to make it diamond plate bed. Since it is opened up already, welding all the braces in for goose neck hitch. Also, making a headache rack that will have stacks up through it...still trying to figure out the best way to do that. Back will be a wedge with led's and heavy rated 2" receiver. Making side boxes to go under the bed sides and side rails 6" tall out of metal plate that hinge down and adding a crane hoist off the back that can be removed with electric winch I am rigging to it.
80BrownK10
Greenwood, SC
Nate
Where did that one guy go that had that bad ass orange k20 I think it was flat bed? It I think was late 70s or 1980? Amazing clean truck , think it was on like 35s. He use to post all the time, I haven't seen him in a few months. Can't remember his username?
mrghostwalker
Connecticut
K10/20
I'm planning to once the mechanicals are all worked out.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I did a bunch of research on them lately. If you buy one, it needs to be for a cab chassis application since our frames are 34” out to out. I spoke to a lady at a CM dealer about a CM AL RS and she had just finished putting one on her square. She seemed to know exactly what to ask CM to do to make it fit our trucks well.
The reason I didn’t follow through is that it limits upward wheel travel if it’s traditionally mounted to the frame rails. Since I wanted to put a camper on the bed and take it through some more difficult off-road stuff, I’d be using a three or four point mounting system that pivots. At that point you have to build a complete subframe, so it’d make more sense just to mount the camper to the subframe.
Long story short, CM can build one to a square’s spec. However, it won’t clear big tires with lots of suspension travel if mounted directly to the frame.
Shorty81
Baby Boomer
North West ohio
Darren
I think you are thinking of @MisterB
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
I don't have any pics right now, but this is a general idea of the basics of what I am shooting for.
thats not bad
jake wells
Can i be me?
Brownsville Kentucky
jake
custom deluxe 10
It is better use spacers to give clearance for spring travel when hauling heavy loads instead of mounting directly to the frame.
I had a one ton with the flat bed and even with the springs maxed out the bottom of the bed was about 6 inches away from the tire.
Turbo4whl
Downingtown, PA
Wayne
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Yep, with one ton springs, or in my case 1-1/4 ton springs there isn’t much of a risk of the tire contacting the bed. I swapped my springs for long travel springs that are softer than a half ton. The top of the tire can go well above the top of the frame, so it’s definitely an issue.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
I do like the look of the wood decked flat beds. Being how my trucks still work for a living, I will go with a steel deck.
seanhatesregister
