Flange bolt question
CRM
Pasco, Washington
Casey
K2500
350 CI
I recently pulled out the crappy dual exhaust someone had previously put in, and I'm planning on going back to the Y pipe and single exhaust piping that the truck came with originally. While pulling the duals I discovered that the passenger side and driver side flange bolts were different lengths. I'm including a picture. My question is: are they actually two different sizes? I've searched all over for an answer but so far I've found nothing. Help me Obi Wan, you're my only hope.
fast 99
Spokane, Washington
Right/pass side should have had a heat riser valve.
CRM
Pasco, Washington
Casey
K2500
350 CI
It does and it has the longer bolts. Now it makes sense. Thank you brother !!
CRM
Pasco, Washington
Casey
K2500
350 CI
Another question....How tight do I tighten the nuts on the flange bolts? Until the spring is compressed all the way?
thatoneskinnymech
