POR 15 Hi Temp coating....Fail!
Steppin Razor
Houston
S
C10 silverado
There are generally 2 temperature ranges for high temp paints and they sometimes cure at different temperatures. 1200 deg. is the higher end. You may have already checked the specs for the necessary cure temperature for the 1200 deg paint to function properly.
I haven't delved too far into it, they don't have a lot of info posted. The instructions it does have don't mention a cure procedure, so hopefully just getting it hot will work (easy enough for headers).
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Cerakote brand coatings seem to hold up pretty well. The stuff is a little costly but a little bit goes a long ways. I bought a 16oz. Bottle of glacier silver (C-7700) to do my exhaust with and only ended up using about 4oz. So far.
Hardest part is prep work, everything needs to be thoroughly degreased and sand blasted for it to adhere.
I did the manifolds for Dads ‘56 about a month ago, they only have about 12 miles worth of cruising on them and about 10 or so heat cycles but they still look fantastic.
The manifolds on my truck were done with VHT header paint, I cured them on the wood stove last winter several times. They have zero miles and maybe about 5 mild heat cycles and they’ve already changed colors. I don’t suspect it will hold up for too long.
Compared to the VHT spray cans at $13-16 per can paying $35 for 4oz. bottle of Cerakote is actually cheaper considering I would have gone through probably 4 rattle cans to do a full dual exhaust.
Auburn, Washington
I think regardless of “how” high temp any of the rattle can hi temp paints are, none of them work well on headers or manifolds. In my experience. Once you get just far enough away from the heat source like past the headers or y pipe it lasts much longer.
But there’s a reason stainless steel and ceramic coatings are popular….
The Freedom Wagon is going to need new headers and exhaust before too long. I can’t wait to try the atf burning method! Never heard of that before…
drumvirt
Virginia
Danny
C-30
Thanks! Great tip. Interesting that a similar technique can be used to prevent wood from rotting for centuries. Char it.
SquareRoot
This wasn't rattle can. 4 oz of brush on. I agree that all rattle can products generally suck.
ali_c20
Austria
Alexander
C20, K5
I disagree, the Motip heat resistant rattle can is great. Withstands temperatures up to 1470°.
I used it for the manifolds on my K5, no rust no chipping off since 2014. Also on the manifolds of my wife's 69 Mustang with a 351w.
Prep needs to be perfect and you have to burn in the paint after it's dry.
Auburn, Washington
Interesting. Must be some good European stuff. It’s almost absent from the internet here. Website is in English and all the retailers are over by you.
sam s
