1986 gmc Sierra classic 305 4bbl carb.
Idles fast even after engine is warm.
I haven't tried that yet as I'm inexperienced with carbs but I'll check it out. The problem just started after it got very cold here -40+ C. It was working fine a couple days ago. I believe it's a factory carb for the 305 121000kms
Kk I'm sure it is warm enough as it was blowing good heat and we went for a cruise down the highway for 20 mins still a fast idle after that.
I was going to ask, is the choke plate open or closed when it's "warm".Weeeeeeellllllll that might have something to do with it
Are you sure it's getting warm enough to kick the choke off? If the choke isn't pulling off, it will stay on the fast idle cam. Try taking the air cleaner off after you think it is fully warm and see if the choke is still on.
More like frozen!! I'm sure any oil or residue that may be on things is quite gummy at that temp.Take the air cleaner off, douse the whole carb in 1-2 cans of carb cleaner while working all the linkages. I bet some stuff is stuck.
I grew up back in the day and everybody drove even when it got super cold. They didn't call school off because it was too cold, they didn't close businesses or tell the police take the day off its too cold. 99percent of cars I 've owned in my life were carburated and I always went to work no matter how cold.If it won't drive in the cold something else is going on. No heat riser, plugged heat riser passage, wrong heads, manifold, air cleaner, inop. Air cleaner heat flap,etc.etc. I worked as a flat rate mechanic 1981?- 2006 my Dad never even owned a a F.I. car tell I was grown and gone, not once at any shop did we ever tell anyone oh it's just too cold.Not once did my Dad skip work because it was too cold.There is nothing wrong with your truck/carb. They were never designed to operate in these conditions.No matter if you had the older "air heat" choke, or the newer electric choke. Being a mechanic, have seen this a bit. Even my old 78, have backed down the choke adjustment, quite a bit, to the point I have to restart it 3 times, so it stays running in cold.Now,i call cold anything below 0. I am probably to the point I shall install a manual choke cable.Just had 2 weeks of 0 to -30,same issues, even to the point, even though I have backed down the "choke" adjustment", it would come back on, when plowing snow.To the point, choke would start to fall back into the carb, and lug the engine down, overrich smoke coming from the exhaust, and lugging down.I have tried to avoid installing a manual choke cable unit,but is the way to go. you have to remember, back in the day,people did not drive in this weather, we are spoiled from what fuel injection does.
