Factory GM Cruise Control
Boone83K10
Boone, NC
Benjamin
I removed the entire factory cruise control setup from my 83 K10 Silverado.
All clips, wires, vacuum hose, speed sensor and module. I did not cut a thing. I will never use it here in the mountains and the servo nipple for vacuum from engine was broken. You can buy a new servo and I will include mine so you can get the core charge back.
The only thing I did not remove was the plungers on the brake support(since I need them for my truck). You can buy the plungers at Advance Auto part# S870P for the brakes/cruise and part# S749 for the vacuum release.
I tested the wiring before I took it out and it worked, just the servo was broke and I don't have the carb studs on my Holley. The Q-jet is long gone when the engine swap happened which is what this is for. You can probably use it with an aftermarket carb if you acquire their studs.
This is plug-n-play straight from GM.
$100 shipped
Splandman
Crescent, OK
Scott
Responded to your PM
Boone83K10
Boone, NC
Benjamin
sold!!!!!!
brentjo
