extended bumpstops
henrym
Albuquerque, NM
Henry
I've had a Pro Comp 6" lift on my truck for a number years now. I installed poly bumpstops, 4" I believe, and of course the ones at the rear are no where close to actually doing anything. Anyone have ideas on how to lower the rear bump stops? I thought of buying heavy duty steel rectangular tubing and cutting, drilling, and installing between the bumpstop and the frame, but not sure of it's stability.
Swims350
Logan WV
none
I know energy suspension has some big longer poly ones for uyp front might have some for the rear as well.
I never really saw a need for em on a lifted truck. I understand stock or close and hauling you might need some. I guess on a lifted truck if it flexes enough it might hit?
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
I thought the same thing. I removed the front left stop because it was a good spot for my compressor's regulator and needed the hole. The front suspension can't flex far enough to need the stops because the 35" tires hit the inner wheel well first, and the back end has Ride-Rites to maintain clearance.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Bottoming out your shocks repeatedly will blow them out or bend them. I had thoughts of making some out of tube. It all depends on how it squats.
Swims350
Logan WV
none
lol I'm braindead today, forgot about shock's limit.
rpcraft
Robert
LS 6.0 364 CID
For the front you can get some 4 inch square tube, cut them in about 2 or three inch width (enough to fit in the brackets), and screw your bump stop to one end, then tack weld a bolt on the end that goes into where the bump stop was, and put a not on top of it...
Use a slightly different thought pattern for the rear (do the rear even have bump stops). I can't recall if my K5 does to be fair but I am sure there are some on the frame rail which makes me think the square tube would work there as well too.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Yes they are on a stamped steel bracket.
rpcraft
Robert
LS 6.0 364 CID
That is what I was thinking. One of those things where i draw a blank unless I am standing there looking at it. Only thing i might do with the square tubular steel bump stop extenders is box them in a little on one side to add strength.
DonnieM
