Engine starts ok, but immediately stops:
fussfeld
east coast
j
c-10
4.3 v-6 262CID
The pcv should rattle when you shake it. What kind or carb on what intake?
Quadrajet, originally off of a 305. Stock q-jet factory manifold.
Georgeb
Wisconsin
George
K10 Burb Z71
Then, like mentioned before you may want to open that carb up, clean it and make sure all the passages are open.
fussfeld
east coast
j
c-10
4.3 v-6 262CID
UPDATE:
Finally running----i put the "junk" reman carb that came the engine back on and it started and kept running no problems.
Thank you everyone for the help.
Before you junk the Q-jet that wasn't supplying fuel to the engine, you might want to try it on a 350 intake again - and using the correct mounting gasket.
fussfeld
east coast
j
c-10
4.3 v-6 262CID
Ah ha.....................
i think that may have been it.
85project
