Engine runs ehh not good
LFR
Boyne city Michigan
Lorin
Custom deluxe K30
Goodwrench 350 5.7 L
What's a harmonic balancer, where's it at is it crucial to time
Skweegle89
Oklahoma
It's the round black wheel in front of your timing cover. It has marks on it that allow you to properly set your timing.
LFR
Boyne city Michigan
Lorin
Custom deluxe K30
How does it slip
350runner
tx
Ceasar
Everything made in China will eventually slip
The harmonic balancer consists of three parts:
An inner hub that mounts on the crankshaft
An outer inertia ring - helps dampen vibration ( also has a timing mark stamped on it)
A rubber isolating ring that bonds the inner hub and inertia ring together:
Sometimes (very rarely) the bond between the rubber ring and either the inner hub or outer ring fails and the inner and outer move in relation to each other. When that happens, the relationship of the timing mark to the position of the crankshaft is altered and can no longer be used to time the engine.
But, I wouldn't be too worried about your harmonic balancer right now.
Here is your original description of the problem:
But it runs horribly. I don't think the plugs or wires have ever been changed but even at 140 degrees f it sputters and dies going into any gear but once it reaches 175+ it's just fine.
I would concentrate on getting your choke set correctly. And don't jump to the conclusion that you need to rebuild your carburetor just yet - q-jets are very dependable.
LFR
Boyne city Michigan
Lorin
Custom deluxe K30
Thanks guys. I think I will order some ac delco plugs and wires from summit racing maybe a cap and rotor. I will have to get some other suff too
Skweegle89
Oklahoma
You might be better off going to the parts store. I think you have to buy $75 worth of stuff from summit of you have to pay shipping. Do you have an in line fuel filter or are you just running the filter inside the carb? Wouldn't hurt to pick one up either way.
Tdabney
