Engine Over hall.
Swims350
Logan WV
none
nope, no torubles ever.
nothing but trouble from old qjets.
holleys eh they are ok,
1jets are too if you get a good one, the old ones that leak or need work suck.
I have a **** ton more problems with Holleys than I've had with Eddy's. Not many issues with Qjets either. Bottom line, each one of the big 3 have their quirks and advantages. So choose what you're most comfy with and the quirk you're willing to deal with and all is well.
IMO, the purpose of the vechile determines which carb to run too. For drag racing I'd run a Holley, but I can't stand a Holley for DD. Keep your fuel filtered well and your gas tank clean you won't have any problem with an Eddy. You can even take off, run a different carb for awhile, and put it right back on a few months later and it will run just fine. Take a Holley off, set it on the shelf for a month, put it back on, it'll leak like hell and need a kit in it. One back fire thru the intake, you're pulling a Holley apart replacing the power valve. You don't have those issues with Qjets or Eddys. But mods on a Holleys and tuneable parts availalbe, the sky is the limit and you can change jetting in a matter of minutes. Eddy isn't bad either but not as many options as Holley. Qjet, PITA to get to the metering rods by taking the whole top off the carb. Pro and Cons, Cons and Pros. Pick your Poison !!!
Driver4r
Nebraska
Trevor
k10,c20
As long as they dont need bushings, Qjets are easy to rebuild IMO.
DawgmanDew
