Engine Mount Question
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
What parts do I need to connect my 5.3L to the frame of my truck? I bought the dirty dingo engine mount adapters but the mounts that came out of the truck look nothing like the mounts that are sold at the auto parts store. Should I be bolting up to the 3 holes or slots?
EvilGenius
Metro Detroit
Darien
The slotted holes are the factory mount holes. See my pic below. Usually engine mount adapters like the dirty dingos are used in conjunction with the original style motor mounts although it would seem like that company would have some installation pics as reference for you.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
I'm asking what the original engine mount looks like. The truck started life with the 6.2L diesel, I think it had a 4.3L in it at what point, and it has the 350 SBC when I got it. The mounts I showed do not look like every mount I come across.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
My question is does either piece of the hinged piece I have get reused? Do I need to buy the mounts below? Does the dirty dingo mount bolt straight to the mount below?
Poppy 87
Bloomingdale GA
R10 Silverado
It's my understanding that the Dingo adapter bolt to the engine and you use the isolation mounts ( your lower picture) for your oem engine/chassis
Sent from my XT1254 using Tapatalk
RoryH19
Rory
R10 Silverado SWB
Yes, the bottom pic, "clamshell" goes on the frame. Then the ls dingo motor mount goes on top of it.
Then the long bolt goes through both on each side.
78shortandwide
Denver
Tom
Here is a pic of my motor mount I’m using the dirty dingo mounts with the stock isolation mounts
GorillaHumper
