- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
you mean parking lamps?
yeah, if i go to my 1990, my 1999(different design for looks but same concept)x2, and go put a battery to some old cars i bet i would see what im guessing.
but now im intrigued, i kinda wanna put 12 volts to 2 old cutlasses and a grand am and see what happens lol i bet some fuses are gonna pop
i wont bother finding the keys tho so no fun there
If you understood me incorrectly, i was saying that the lights are mercury switched and switched to parking lamps. So if hood open, no light, if hood open and headlights on, works. if hood closed, headlight switch off, no light. if hood closed, headlight switch on, no light still. when i put some on my square(Im putting more than one on since i have so many) I am going to put 2 on hood open and the other+ will be switched and maybe mounted elsewhere. i think held on with just rivets?
to be clear, we are talking about these, right?
You must be registered for see images attachYou must be registered for see images attach
Right, no parking lights required for operation of the underhood light. They get constant 12v and come on when the hood opens.
This one came in my last truck ('79 K15). I took it out before I sold it thinking I'd use it in my '85, but I bought a 90's under hood light instead. It does work, but I noticed the rubber seal is dried out, so the lens does not hold as tight as it should. A gasket could probably be made from an old innertube. It's a 1 wire hook up and grounds through the body. If you're interested, PM your address and I'll send it out.
You must be registered for see images attachYou must be registered for see images attachYou must be registered for see images attach
They DO exist!!! That's cool!
