Engine Backfire Diagnosis Led to Wiped cam Lobes
Skweegle89
Oklahoma
85swb "Fancy"
Dizzy is stabbed. You mentioned needing to limit the vac advance. How do I go about doing that?
Skweegle89
Oklahoma
85swb "Fancy"
I'm baffled. I have power to the distributor, but none to the plug wires. Brand new dizzy.
350runner
tx
Ceasar
12v?
350runner
tx
Ceasar
Connected to the batt terminal not tach? Double check
Skweegle89
Oklahoma
85swb "Fancy"
I figured that Bart out. Best case scenario, the timing chain has jumped.
Carb'ed Vortec 350
Also make sure the contact on the rotor is making contact to the center stub on the coil. I have had those lose contact before and leave me with no spark. And leave the vacuum advance unhooked and plugged on the carb side until you get it timed.
Skweegle89
Oklahoma
85swb "Fancy"
Had to clean the plugs again to get it to start. Runs like complete crap. Backfires every 3rd or 4th revolution. Only hitting on a few cylinders. Off to buy yet another set of spark plugs so we can run a compression test.
350runner
tx
Ceasar
Pull the valve covers and see if the rockers are all moving the same or are loose.
Skweegle89
Oklahoma
85swb "Fancy"
I will have to wait until I can get get some more valve cover gaskets. These are already leaking and I don't think they will make the trip.
350runner
tx
Ceasar
Good deal
Skweegle89
Oklahoma
85swb "Fancy"
I'm running out of possible scenarios.
350runner
tx
Ceasar
Bud I really think it's like I told you I'm that pm. A complain test will tell you as well as the rocker movement.
Skweegle89
Oklahoma
85swb "Fancy"
I will check that and a couple more things this week. I did acquire a 454 out of one of our old city fire trucks. It's an 86 the city bought brand new back in 86. 50k miles and I got it for the low low price of free. It's got a knock though, so it will need rebuilt.
350runner
tx
Ceasar
See I knew you had a 454 LOL! ;-)
Skweegle89
Oklahoma
85swb "Fancy"
Lol as long as it's not a conflict of interest with the city, being as how on on city council were good to go. I would rather get the 350 running so I have time to build the 454 like I want it. Idk, I'm just getting really fed up.
kobedemello
