Electronic speedo 79 c10.
randomTruckKid
Rockport tx
I'm wondering if anyone knows of any speedo gauges for a electronic vss. I have a 90s 700r4 in my truck and I need to put a electronic vss in it. However I don't know of any gauges besides one. (Automeeter 7004) that has thw ability for one and to be calabrated. Anyone have some help?
dd1990
Ventura CA
Suburban 1500
You dont want to use Dakota Digital? I used Dakota Digital on my 90 Burb i just connect the vss signal wire from 18 pin connector to my dakota digital speed snd on the digital box worked fine after calibration
randomTruckKid
Rockport tx
I actually haven't heard of them. But imma look into that, though I need something that isn't extremely expensive.
What not swap the speedometer drive and tailshaft housing from am earlier 700r4 and keep your cable speedo? If for some reason you can't find cable speedo 700r4 to rob parts from,you can use the speedo drive from a BOP th350 and a 700r4 drive gear and clip with your tail housing. Looks like someone sells the whole mess on Amazon and I put up a link to calculate gears.https://transmissioncenter.net/shop/speedometer-gear-calculator/
JUKA
