Electric Rear Window
59840Surfer
Montana
Joe
It works - but only from the front switch.
Years ago I fixed the cable drive and it will NEVER fail again - I swear! The fix is IN!
But the key switch doesn't work - and frankly, I never even noticed if it is accessible or not with the window UP.
Any clues as to why the keyswitch failed - are they available - do the wires rot off?
Whazzup?
In the harness back to the tailgate, there's an UP wire, a DOWN wire and also a power wire that supplies 12v to the key switch. Check for power at that wire. It's probably corroded at the connector under the rear of the body.
59840Surfer
Montana
Joe
Okay.
I'll be back in town on Monday...I'm in the woods cutting firewook for a few days.
There is a spray can product named DeOxit that you can used to clean oxidation and corrosion off the electrical connectors. It will help make better electrical contact at the old connectors. I used to buy it at Radio Shack (now gone), but I’m sure other places sell it.
59840Surfer
Montana
Joe
I'm going to open the panel again - I hate to open that panel --- and this time I'll look for that switch.
The week is early and my chores are close to caught-up on - so I might get time to do it.
I wish the switch was remote mounted off to the side with a relay rod to the center for the keylock hole.
Honestly --- this rear window regulator is the dumbest design I've ever seen - but I think I cured it of destroying cables once and for all.
Camar068
10 yrs Air Force
so....lil derail, but who's to say you can't use that same mechanism for a rear CAB window? PM me and I'll stick a post up about it if needed to carry over there.
just a thought when I read the post, my apologies to OP.
59840Surfer
Montana
Joe
No problem ... yours is a salient thought.
Camar068
10 yrs Air Force
R Carnella
Long island
Rich
Suburban V2500
It's most likely a poor connection at the tailgate, the two pin connector comes from the dash switch then there's a single power wire that feeds the tailgate key switch
350 w/203
I hope this loads and helps . . .
  • Tailgate power window repair.doc
jlyon1006
