Electric fan conversion
Obwonkonobe
AZ
Ethan
C10 custom deluxe
The Az heat has led to my clutch fan locking up after 10 minutes of driving every day this week, and I’m done sounding like a Mac truck and feeling all that drag in the pedal. So I’m finally pulling the trigger on a long planned electric fan conversion. Today I ripped out the stock fan and grabbed a 2 speed fan (part number 620-101) from an early 90s Taurus, 114 bucks on amazon supposedly will get me one of the best fans money can buy without going totally nuts. It’s advertised to flow 1800cfm on low, and 2700 on high, think that’ll be adequate? I’ll have to build another shroud as the included one is smaller than my radiator. I’m just sharing my experience, feel free to leave advice as this is my first time doing a fan swap
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Have you already upgraded your alternator?
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Yeah I’m running a 110 amp alternator from some early 90s truck that still ran a vbelt, I have lots of things drawing from it and still see 13.5 volts at all times
4WDKC
Southern Florida
Kacy
should do the job I recommend you wire it in with a Volvo relay. It has 2 inputs to enable the fan high and low, and also eliminate the 3rd relay needed to switch between high and low. Using a BMW 2 temp switch will make this easy to install.
this is probably the best write up I have seen for this
http://www.syty.net/forums/forum/sy...es/101745-wiring-2-speed-fan-with-volvo-relay
omillan99
El Paso, TX
Oscar
K20 Scottsdale
350 4 Bolt
@4WDKC Do you have a write up on this?
omillan99
El Paso, TX
Oscar
K20 Scottsdale
350 4 Bolt
Sorry hadn't had breakfast and didn't see it. I appreciate it!
Obwonkonobe
AZ
Ethan
C10 custom deluxe
I’ve actually got a few 40 amp relays laying around, one will handle the low speed, and then 2 more will be wired in parallel to handle the high, effectively making an 80 amp relay since they share the load. And my msd efi system has trigger wires for a 2 speed fan to control it at whatever temps I want, should be pretty good!
4WDKC
Southern Florida
Kacy
I liked this because its simple to hook up, doesnt take alot of space and cheap, the fan they use is supposedly the same motor as the Taurus but it bolts to the shroud allowing it to be easily removed and custom shroud made. Here is the one I made for my vette
Camar068
10 yrs Air Force
Have read good things about the volvo control mod.
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Dude is that a baking sheet! I’m trying to mock-up mounts with strips of metal stock and sheet metal but if it doesn’t work out, I’m defiantly going that route
Daveo91Burb
Vancouver, WA
Dave
V2500 Silverado Suburban
Vortec 383, modified TBI/4L80e
Following this thread! I have a buddy that’s trying to part out at least one if not two Volvo’s, maybe I can snag a relay or two
4WDKC
Southern Florida
Kacy
yes it is, it was cheaper than buying a sheet of stainless steel and bending it and it is the correct size to cover the entire radiator on the vette. Someone else came up with the idea and nicknamed it Pan shroud
grandscapesllc
arizona
scott
I used the dual fan out of a 2004 ford windstar. Was very easy setup and the shroud covers the entire radiator. I have pics somewhere
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Just a look at my relays, all are 40 amps, but the two smaller ones are getting wired in parallel this afternoon to effectively make a single 80 amp for the high speed
bglendon
