Electric choke
86suburbanNJ609
South Jersey
Aaron
Suburban
I have the edlebrock 1406 carb on the burb and the electric choke is not hooked up. Never was since I bought it about 8 months ago. My question is could I be doing damage to the carb? I see two tabs on choke but only one red wire that is in the vicinity of it could someone post a pic of there's please.
DanMcG
Central NY
k10 k10
Somebody will correct me if I'm wrong , but the wiring diagram shows the choke hot wire is light blue and the other terminal should be a ground.
I just looked at my 85 and the hot wire is red also. :shrug:
86suburbanNJ609
South Jersey
Aaron
Suburban
So there's a ground hanging around somewhere huh? Ok I'll check it out. The truck starts fine without but if it's a function of the carb I want it to operate fully
DanMcG
Central NY
k10 k10
You probably won't find it on the truck, you'll have to make one like this.
86suburbanNJ609
South Jersey
Aaron
Suburban
Ok nice there's one in the box the PO gave me with the truck I didn't have a clue where it went thanks.
The yellow choke light comes on once in a while what's that indicating?
MikeB
You're not going to damage the carb, you'll just have some stutters and hesitation until the engine warms up, especially in the winter.
Keep in mind that 12 volts gradually opens the choke plate. How are you keeping it open now?
78C10BigTen
pennsylvannia
C10 BIG TEN
Heres how my eddys set up. Mine didnt have a choke wire so the other black wire i ran from the fuse box off a terminal that was hot only with the key on. (I only had black wire so i used it)
kenfoy
cal
ken
From the image you sent it appears that your ground wire is connected to the choke body on the carb. There is a gasket between the carb and the manifold that may not be allowing a good ground. I would recommend moving the connection to a clean area on the block or frame. While there may be those who would argue that your present ground connection is good, I would change it to be sure.
If the "hot" wire tests 12 volts from the wire connection on the choke to a ground point, and it is hot when ignition is on, you should be good to go.
After changing to a better ground point, with the ignition off, pull your air cleaner so you can see the choke blade. turn on the ignition and watch the blade. It should move (probably slowly) to the "open" or not choked position. If so, you are good to go.
Regards,
El Viejo
Rusty Nail
Rusty
350sbc
*theirs
Wtf "there's"?
chengny
Provided the choke heater wiring is in good condition, and the CHOKE warning light illuminates...it could possibly be telling you that your oil pressure is low (like under 10 psi). I would investigate it - if you don't have a gauge package.
86suburbanNJ609
South Jersey
Aaron
Suburban
I got it it's hooked up just lights up for for maybe 3 seconds and turns off. The ground wire was chewed up put a new one on back to the carb. Thanks for the answers guys even the smart ones about grammar.
Rusty Nail
Rusty
350sbc
I imagine that the light is providing an indicator of low oil pressure while it builds following start up. There is no need for much concern unless it doesn't go off!
86suburbanNJ609
South Jersey
Aaron
Suburban
Right on
I'm just getting everything slowly but surely hooked up on her. I'm trying to keep everything as close to factory as possible the wife has been driving it I just want it safe simple and reliable for her you know.
chengny
Not that you even asked, but here is how the choke heater/warning light circuits work as from the factory:
Elhuichol
