EFI Sending Units
Bama69
Alabama
Joe
87 v10 4wd - I’m currently running the stock 350 with TBI. In the near future plan on replacing it with a 383 stroker with EFI. I need to replace the sending units and wondering if I can run the TBI with a higher fuel flow sending unit that will be needed for the EFI? If so, are there any other mods I would need to make such as fuel lines, fuel filter, dual tank valve, etc.?
You just change the pump and screen. An Ep381 will probably due it. But you'll need to compare what your EFI wants VS. What an EP381 can provide.
Moderator
Yeah, people upgrade to the TBI sending units for their high pressure EFI swaps that require high pressure pumps. You just need pumps for the sending units you already have.
Ed Stewart
