edelbrock 600 cfm
Jimbo166
Canada
c10 scottsdale
hey guys i put a edelbrock 600 cfm carn on my 350sb and i put all the propper atachements for the throttle and everything and where do i put the springs because when i start it up the throttle is stuck wide open?
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
If you still have the engine pulling tab that bolts to your intake on the driver's side front, that's a good place to put them.
fowjacob
Lubbock,TX
c3500
383 Stroker
https://www.dropbox.com/s/e4o8hrcjt1k9vr1/Photo Nov 01, 9 48 04 PM.jpg
https://www.dropbox.com/s/mtc947rv1h9u131/Photo Nov 01, 9 48 33 PM.jpg
https://www.dropbox.com/s/d9olfetdqajs55h/Photo Nov 01, 9 48 56 PM.jpg
This is where and how mine is hope it helps
crazy4offroad
Curt
K-10
350/SM465/NP205
Man that spring looks like it's a strong one, pedal hard to push? It is also not very safe. Stock throttle springs have 2 springs, a larger diameter one with a smaller diameter one inside. Reason being if one spring breaks you have another one to keep it from going WOT. And you should be able to tell if one beaks because your throttle would get pretty light.
Whatever works, but yeah, that looks tough. Rob that off your screen door closure didja???
IIRC, it's actually SUPPOSED to go on the lower portion of the throttle lever and pull toward the back of the motor, instead of the upper portion and pulled to the front.
And yes, the dual spring is the proper OE way to go, but rarely done that way on aftermarket carb swaps. Thing to consider, these trucks have a cable operated throttle, NOT solid rod where you can pick the gas pedal off the floor and to get out of a WOT situation. Been there done that a couple times on the 64 GMC that used a solid rod thank god, when a motor mount broke, motor came up and binded the linkage with a WOT. Other thing to consider using a cable, they can get stiff and hang up. It's not practical to lube then while installed, but if I've ever got a motor out or cable disconnected I usually hit is with some white lithium grease spray or try to get some graphite powder down the cable housing which is tough to do at times.
crazy4offroad
Curt
K-10
350/SM465/NP205
I had mine set up like this for a while till I did the auto trans swap, then the detent cable was in the way.
fowjacob
Lubbock,TX
c3500
383 Stroker
I think the pedal is perfect not to hard not to easy
fowjacob
Lubbock,TX
c3500
383 Stroker
Have no idea where that came from but could you show me the oem set plz if you can
Jimbo166
Canada
c10 scottsdale
hey guys i found the location and everything works great, also this carb is the best thing ive done performance wise makes the truck run so much better.
Good News. So did this carb go on an original intake or an aftermarket Eddy intake?
82chevy350
Van Buren, AR
Joey
C10, K10, K5
I must say those eddys are pretty reliable
Jimbo166
Canada
c10 scottsdale
it went on a edelbrock manifold and i just put an edelbrock elite air cleaner which i will add a picture of soon.
Jimbo166
Canada
c10 scottsdale
edelbrock elite air cleaner with a k&n tall boy filter
blueghost86
